Tilt Angle Request | SatelliteGuys.US
Tilt Angle Request
knish
Hia all,
Just about to install my new triple LNB Directv dish and was wondering if there's anybody out there that can give me the correct tilt angle for Toronto, Canada. I have all the other info to set it up.
Thanks in advance
Knish
I was going to use my setup to get it for you but you need to put your zip code in the welcome page when you first plug in . I think memory in the box will then tell you all the info. I am in Key Largo less than a degree west of your longitude and my tilt is 44 degrees right tilt so think yours is about 45 degrees right tilt. I think lattitude only affects azimuth and vertical settings but could be wrong. You are at 43 degrees 40 minutes north, 079 degrees 22 minutes west, I am 80 degrees west. I assume Canadian zip codes work but the closest one in US will be the same.
espn game plan
National feeds instead of locals?
