Time Available Drifting / Changing DVR 625 | SatelliteGuys.US
dgray9
22
I own a Dish 625 DVR in Single Mode .
Up-to-date software Version: L540 .
After the most recent software update ( L540 ) the Time Available on the DVR Menue screen drifts usually downward as I switch channels and switch ( Swap button ) between the two tuners .
i.e. 4h 00m .... 3h 59m ... 3h 57m... etc.
It behaves as if the dvr is not totally erasing / ignoring the data recorded from the previous channel after the channel is changed .
A soft reset restores the Time Available to the correct value, but then the value continues to drift lower as I watch and switch channels .
Any memory discrepancy in the dvr is of concern to me since I have quite a few recordings on the dvr .
I have tried both soft resets and hard (unplug) resets .
Thank you .
Thank you .
You might give Dishnetwork Tech Support a call and ask them.:confused:
Dish programing question
TV Everywhere and HDTV Multi-Room Extender
