Timer Question- Event Time Change | SatelliteGuys.US
darrencp22
2,966
Lockport, NY (Buffalo Suburb)
I scheduled a single event timer to record a sports event this sat. I just learned the event has been moved from 7 to 4pm. Will the 622 know to reschedule the record time or am I out of luck? I wont be home this weekend so I will not be able to reset the timer.
And check the guide to see if it has been changed yet. If not, play it safe and set a manual timer IF you still can (gone already?).
If I were there I would just check it :) The reason I ask is i'm at work and ready to head out of town directly from here.
It is not a manual timer... assume the guide updated correctly. will the event record? It is a single event time.
I guess you will know when you get home.
Edmonton @ Phoenix NHL CI 556
Rugby World Cup 2007 Final - What Channel On Dish Network
