Timers different than Daily Scheduled recording | SatelliteGuys.US
Mike88
197
5
Illinois
I'm using a 722K DVR. Last week I used the search function for a program my wife wanted, found it & set it to record.
I always verify the Daily Schedule at the beginning of the week & the program was not scheduled. I looked at Timers & it was set to record. Then looked at the guide & the program was listed but was not indicated to record. IOW it's not a matter of the guide changing or being wrong.
Is this a new problem where Timers indicate a program will be recorded but the DVR Daily Schedule & EPG indicate it will not?
Sounds like the same old problem to me. I think that there is hidden data in the guide that is used in some way. Maybe that changed, but since it is hidden, you can't see it. I have similar issues with the H3.
Remote Control Device Setting
**Team Summit Update**
