Well I finally got tired of waiting on Dish to decide to release the SuperDish to the general population (i.e. those that want it for HDTV not LIL). So, I got the ladder out and climbed up on the roof and planted another satellite Dish...
It was a big pain to point to 105. In fact it took me quite a while to get it to work. I was using a 35" dish (90cm) and a Dishnetwork LNB (well expressvu). What I finally ended up doing was peaking the dish on 110. I swapped out the LNB for a DBS one, and peaked it on 110 (can get 125 signal with a 35" dish btw). Once I had it pegged, I swapped out the LNB and slowly rotated the dish until 105 finally twitched. Then I just barely moved it around until it peaked. Then bolted it down tight.
Then I had fun with the SW21/SW64. It turns out that the SW64 has to be on input #1 of the SW21. I first had the 105 on input 1 and the SW64 on #2 and it could not find satellites properly. It found 110 and 1/2 of 105... I went up on the roof to see if I could diagnose it better (i.e. try one switch at a time) when it came to me that maybe the SW64 has to be on #1. Sure enough that fixed it.
I am attaching some pictures. Of the antenna farm. I have 24" dishes on 119 and 110, a 35" Dish on 61.5 and a 35" dish on 105. In the pictures the 105 one is in the back or on the right depending on which picture.
The only issue I have for the satellite experts is why are the even transponders reading 15 points higher than the odd ones on 105?
