Titanium ASC1 and JP1 IR discrete codes | SatelliteGuys.US
iBoston
2,647
2,214
North Central
I am a big fan of JP1. It allows me to use a JP1 remote to program it to my specifications. That way, i have one remote that controls all my devices so i don't need to fiddle with remotes. It also allows me to program which buttons do what.
To sum up, i have uploaded the IR discrete codes for the Titanium ASC1 remote so if you are like me and have a JP1 remote, can quickly program your remote. This is for the RemoteMaster/IR software.
I maybe the only geek that does this, but just in case...
http://www.hifi-remote.com/forums/dload.php?action=file&file_id=12874
Reactions: FTA4PA and Titanium
Oh, by the way, i also created IR discrete codes for the following STB's
GeosatPro MicroHD
Amiko Mini HDSE
Linkbox 8000 HD
Skybox F5
I have a JP1 compatible remote in my 'save for future use' boxes somewhere that I want to experiment with over the winter. Gonna download the Amiko Mini HD SE codes. Thanks iBoston! :bow
Let me tell you, JP1 is the only way to go.. If you need any help with it, i'd be more than happy to help out. I have one remote that controls 12 devices. It handles my TV,Receiver,Roku,DVD,DVR,MediaPlayer,AmikoSTB,TitaniumASC1, and my Digital picture frame. All on one remote. :first
Reactions: FTA4PA
Sounds good! Will do. Thanks!:)
Scan?
is anyone DXing ku?
