Titanium C1WPLL LNBF vs Titanium C1WPLL LNBF with WiMax Filter | SatelliteGuys.US
dl76
225
131
South Carolina
Hello Guys, Is there a difference between the two? I do not have so much of 4g/LTE towers near me , but do have 4 or 5 cable modems that put off strong wifi , near me , including my router. I have the lite version Titaniums lnb. Would it make since to upgrade?
C1W-PLL vs C1-PLL.
C1-PLL has WiMax filter but is not wideband. If you are having interference,yes it should help. You will lose the wider bandwith.(Which is of little concern unless you get over into the Atlantic Satellites) Other than that they are the same.
The WiMax filter seems to have helped some intermittent problems at my location.I originally had the C2W-Pll...same as C1W-Pll but dual outputs.
It won't fix a problem you don't have though.;)
A spare lnbf is always nice to have handy if you need it someday.
Creative Recycling
I think my Powermax VBox Died!!!
