Titanium Satellite ASC1 Firmware Update 20140702v1 Released | SatelliteGuys.US
  • Thread starter Thread starter Titanium
  • Start date Start date
  • Replies Replies 0
  • Views Views 804
Titanium
AI6US
7,687
9,157
Meadow Vista, Northern California
New and Improved ASC1 firmware is now available for download - 20140702v1 at: http://titaniumsatellite.com/updates
Important Notice: This firmware can only be loaded with ASC1 Loader/Editor version 1.7. Once this firmware is loaded, only Loader/Editor version 1.7 and higher will read and write Satellite Lists. Previous Satellite Lists are compatible and can be edited and loaded with version 1.7.
  • Modify - Positioner Default 0000: Position count number 0000 is now a default, no move position. Default position 0000 is not a motor position and cannot be saved as a motor position. This rule is implemented to prevent the motor from returning to position 0000 when setting a new DiSEqC 1.2 satellite motor setting.
  • Modify - Fixed Step Mode Voltage: The M1/M2 motor voltage is now fixed in the single step motor move mode and no longer ramps in/out. This is to provide more power for heavy load lifting when bringing a heavy dish up from the horizon. This modification minimizes move error messages which could occur during extremely slow motor movement, which delayed sensor counts from being issued by the motor.
Thank you for your continued support of the ASC1 and for your feedback to make it even better!
Ku Band setup/tune-up tool\aide
95W on an 18'' dish
