Tivo on ebay | SatelliteGuys.US
Tivo on ebay
jvstrat
20
If I buy a 120gb Samsung Direct Tivo on e-bay with the access card, will I be able to activate it with direct tv or will I run into problems? Also do you think that since I will be paying for the dvr protection plan that they will cover the one I would buy on e-bay?
Buying used you are taking a chance if the seller is honest about their claims, no charges on the card and the overall condition of the unit you can get a good deal.
But as always BUYER BEWARE!!
As far as the DVR protection plan I would contact the provider of that contract and ask them directly.
Good luck with it.
Unless the card is virgin, you will not be able to activate it. :no
Dish or DirecTV for HD
Direct PR- Dozen new Locals launch at 3AM tonight
