TNAP 6.0. Beta-test images | SatelliteGuys.US
primestar31
14,535
16,417
Beta Omicron Delta III
Load at your own risk, but these are from El Bandido, though are untested.
EDIT. I removed the link, best to not load these until they are ready.
Here's the thread at Legit:
Reactions: norman881
I tried loading the osmio4kplus TNAP6 today into a vacant slot. It loaded, then autorestored and I was able to run it. But I found it wouldn't connect to my network so I restarted and it then hung. To recover, I had to use the emergency power-off method where you power on, press the MENU key repeatedly, then select a different slot to boot from.
Reactions: primestar31
I see you've already let El Bandido know that over at Legit.
I had all of the same issues.
