TO GET VOOM: can I connect a sw21 to a DPP4 to get the 61.5 | SatelliteGuys.US
ScottChez
1,651
142
I have a DPP 44 with a DIsh Pro Plus Twin and a DP pointing at 148 all going to 5 tuner ( a 645, 522, and a 4900)
I want to now add the 4th SAT , can a old DIsh Legacy LNB that was once connected to a SW21 on the old Dish 500 connect to the DPP4 and work or does everything ahve to be DIsh Pro to work with a DPP 44 switch?
In other works all SAT and Switches are Dish Pro but now I want to use the old Legacy Dish 500 to get 61.5 (need 148 still for my locals).
It would be a temp thing till the Voom is mirroed to 148 (cant wait)
It has to be Dish Pro.
So just switch the LNB to Dish Pro Dual/Single and plug it into the 3rd port of the DPP44 and you'll be all set.
Take a close look at what Dish has just done to us
942/switches/diplexer questions
