I got some good stuff today: 1 brand new Channel Master 75e Primestar/Starband dish, with mounts and hardware.
1 1.0 meter Channel Master, tripod LNB mount. - Also got another 1 meter Primestar dish that seems identical, but doesn't say Channel Master on it, but it might be.
Also got some misc items like scalar rings, feedhorn etc. - All for free. That makes it even better.
Questions:
-I don't have a multi-switch but will be ordering some. Can you use just H or V to get those TPs? i.e can I run H or V to a diseqc port, then select that port on the receiver just until I get a switch? Or will that affect the LNB somehow?
-Once I get the multi-switches, I just run H and V from the LNB to the switch, then from the switch to the Diseqc, correct? Then on the receiver, do I just choose Universal LNB and whatever Diseqc port it is in?
-Am I correct in assuming that this Chapparal feedhorn is C and Ku?
Free Image Hosting by ImageBam.com
Questions:
