I just bought the HD-A2 and apparently it's already exceeded my technological expertise.
Neither have I been able to get a satisfactory answer by searching.
Using the HDMI connection to my HDTV's DVI with an adapter, some dvds (HD and SD) seem to play fine but others won't provide any video - only sound. Everything seems to work ok with component but I'm already using my only 2 component connections on the TV and would rather stay away from a switcher.
I read that this issue can be fixed with a firmware update, which I attempted today by downloading 2.5 from the Toshiba site and burning it to a cd.
The problem is when I try to install the upgrade the A-2 it says something about the update not being a valid update for this player.
So 2 questions:
Is 2.5 the correct upgrade and does it resolve the HDMI / DVI problems?
Have others successfully upgraded to it by downloadeding & burning their own cd? I'm not really near enough to do a hardwire ethernet hookup, so I'd have to borrow a wireless adapter from one of my computers and by then I'm so far out of my knowledge range it's laughable.
And GP, you really need to help me out here since you were influential in my deciding on this unit.
So 2 questions:
