Toshiba TRX-120S Ku sat type? | SatelliteGuys.US
ussexplroer
272
4
I have been wondering and looking up information on this for a while.
When I goto setup a ku band sat for analog in my Toshiba receiver. It lists what type. The manual explains there is different types of ku band sats. THere is a pre programmed list but it is outdated. I know if I select through the different ones. Sometimes I get feeds. sometimes I do not. It also seems to change the frequency a little.
so how can I update or tell what to use for what new sat? I can guess but the list has like 12 sats and it would be like the needle in a hay stack.
thanks for any help,
Josh
I always used the format that said Anik-KU 32ch. That seemed to get most of the channels on most of the ku birds. SBS6 used to be different, and had less than that amount, but that sat has been replaced by Gal 17 now, so should be same format on ku as the rest of the Galaxies.
x4 signal issues
Brasilsat B1
