Toshiba Trx-1520? | SatelliteGuys.US
Toshiba Trx-1520?
Rufus_74
SatelliteGuys Guru
120
This weekend I picked up one of these units at local swap meet. the price was cheap enough, but unfortunately it didn't come with a remote. can you setup the receiver to receive analog ku band feeds without the remote. The remotes for these units are quite expensive on the internet, almost $80. When I tried plugging it in all it said was c-band, do you have to switch it to ku band for it to work. i'm a little confused at the moment and any help or suggestions would be greatly appreciated.
Rufus :confused:
Great receiver…but yes you would need the remote to switch it to KU band. There are some menu functions that you need to get into to switch it to KU.
I don't know if a Universal will work or not.
Iceberg said:
spin
without the remote he really couldnt do much :)
ICE
i assumed he found one already so he needed a manual to operate
anyway here is a place for remotes ...oh and guys in case u need to fix yours
http://www.originalremotecontrols.com/remotes_001.htm
this is the one ..but 69.00
http://www.dvdremotecontrols.com/Mfrs/Toshiba/ToshibaDSS/23120313.htm
or here http://www.remotecontrolsinc.com/detail.aspx?ID=33306
and this will operate the receiver
http://www.universalremote.com/products/index.php?item=sl7000
Fortec Lifetime Ultra Freezing on IA6 scan
IA 8 and the Ka band
