Total Signal Loss | SatelliteGuys.US
Total Signal Loss
jannah
SatelliteGuys Guru
122
183
Southeastern U.S.
I posted back in September about a partial signal loss after Hurricane Dorian, still had my locals and about half of the other channels. Port 1 was out. Tech came out and all was was good, strong signal and everything was working great.
November 1 the same issue again, Port 1 out. There had been a storm a couple days before and some wind. I called and can't get an appointment til the 13th.
Get home from work this past Friday and total signal loss. Port 1 and 2 out. I call Dish and get a tech out on the 11th. She realigns the dish and said a bolt was a little loose. All good, great signal and back to normal.
Tuesday morning turn on the TV and once again total signal loss again. No storm, no wind. Tech is coming out again today.
So, while I'm waiting does anyone have thoughts on what is causing this issue ? Thanks.
Different tech today, he thought it might be a problem in the hub. But, turns out the arm on the mast was loose, he took everything down and repositioned the dish to a new area.
Hopefully, my signal problems are done.
Reactions: MikeD-C05
If the mast was loose enough for him to relocate the whole thing, chances are the seal failed and water got in between the mast and your roof. Might want to check that area out for water damage..
Reactions: HipKat
Dish plans to drop millions of Boost Customers
Lost Dish network Int'l Brasilian channel 118.7
