Transferring recordings to DVD | SatelliteGuys.US
JTOUPS
31
Has anyone yet to figure out (if possible) the easiest way to transfer recordings to a computer, for DVD burning purposes?
(Basically like TIVO does with their file transferring.)
Thank you for any help!
Dish stores programming in perfect digital format, therefore the content providers do not want Dish to allow file transfer for dvd burning. Tivo records a lesser quality mpeg2 file so they are allowed to allow file transfers. Easiest solutions? Hook up OTA to your HTPC and that way all your dvr files are already on your computer.
BTY recording to DVD is SD resolution any way, so you might as well use S-Video connection.
There is also the dishrip Yahoo group if you want to do it faster than real time, and maintain the original quality. That process it not easy, though, since you must temporarily remove your disk from the IRD.
June - E- Letter
622-Please wait...
