Transformers Web Enabled Update question | SatelliteGuys.US
SatinKzo
6,232
83
Louisiana
What is the "Web Enabled Update" everytime I put transformers into my A2? Anyone else get this each time you watch the movie? I figured ok, one time, no big deal, but it's every time for me.
Well, I found that it does this on the add-on drive for the 360, but only 1 other person reported (that I can find after wading around at AVS) it on their stand-alone players.
I know it can be cancelled. I was just curious as some users said it only appeared 1 time on their players.
It needs to download the list of web-enabled extras everytime, so thats what the wait is for.
Look at the list of extras, it could change. Not sure if it has or not, tho.
-John
Word of warning XBox HD-DVD users--
On the 360 Add-on, you've got to be very careful to disable cookies or it may lock up on you on subsequent viewings. AVSforum threads confirm this--I ran into an unfortunately common freeze after an initial load and web-content download. You get a brief 'web update' screen each time you load the disc, but it only takes a few seconds. Just keep the cookies turned off/denied and you should be o.k.
Sounds similar to what happens with Heroes disc 2 (the one with web-enabled features). The disc freezes with subsequent viewings. The fix is to clear the HD DVD drive memory in the system blade of the dashboard. I assume the same is true for Transformers, but I haven't had any freezes....yet.
Toshiba HD-A2 with DVI HDTV
I want my HD-DVDs to be full screen, not 2.35-1
