Transmitter azimuth - magnetic deviation? | SatelliteGuys.US
mchomicz
SatelliteGuys Guru
I've been reading up on satellite setups and it appears that magnetic deviation is all-important in performing satellite installation (i.e. magnetic north has to be corrected with magnetic deviation in order to find actual magnetic north based on site location; also known as difference in magnetic south versus "true south")
Here is my question. Is the same true for transmitter azimuths for OTA transmitters provided on www.antennaweb.org/aw/Address.aspx ? Or does that site already take into account magnetic deviation and provides corrected azimuth readouts (in other words I adjust my antenna direction based on compass readout and don't have to correct for magnetic deviation).
Thanks,
Michael
The antennaweb.org azimuths are compass readings from your location. You don't need to worry about declination. However, if you attempt to translate those azimuths from a map of your house and geographical area, then you will need to adjust them for declination.
help -- ota hd issues
OTA 5.1 dolby
