Transponders On 99w With Correct Time?? | SatelliteGuys.US
Thanks guys. I'll have to check on that AFN color bars one to see if it works.
I record some programming on the Caribbean mux and need a transponder on 99w that will set the time on my receivers when I boot them up without having to move the dish to 97w to do that.
And in case you were wondering, I keep the power cords disconnected for all my Vbox dish movers when they are not in use hoping that will make them last longer now that they cost over 3 times what I paid for the ones I've got, IF you can find them.
Yeah, I'm cheap!!;)
Just saying..................
Reactions: c-spand and KE4EST
I would guess the scrambled AFN 3900V would. I think there are colorbars that are ITC.
BINGO clucas!!! Thanks a bunch as I did scan in that TP for open channels and it brought back 3 test cards that were ITC and with the correct UTC time setting!! :clapping My Micro HD automatically set the time pretty much as soon as I scanned 3900 in.
Just saying...................
