Travel with 722 model? | SatelliteGuys.US
dummy
34
I currently use a VIP211 at each of two homes and on the road with my travel trailer. I'm thinking of getting a 722 DVR and wonder if there are any special considerations or problems that might be associated with unhooking the 722 from one place and moving it to another and re-hooking up. I realize I can't drop the unit and things like that. I'm referring to any technical issues associated with cabling, switches, etc.
Finally, I'm only talking about moving the 722 itself. I already have a outside dish installed at each place.
Thanks for any comments!
Garys- That comment went way over my head. At both of my homes I only have a single RG-6 cable to goes from inside the house up to the dish on the roof. Can you tell me a little more about those switches? Would DISH install them for me and can they travel easily?
What type of dish do you have, Is it for 2 satelites or 3?
If you have the 1000.2 dish with 3 satellites(3 round circles), you will be fine with 1 cable just like you currently have.
If you have only 2 satellites(Dish 500) then you need to make sure you have the correct LNB on the dish, a Dish Pro Plus(DPP) so that you can get by with 1 cable from the dish.
Dumb question...Just wondering though...
How long before can use DIU?
