Traxis DBS1500 | SatelliteGuys.US
Traxis DBS1500
old post I had
Traxis 1500....simple model unit. 2 drawbacks I know of (I donot have one but worked with one)
-no blind scan
-when you log in the frequencies, it is very sensative...which is good and bad. The bad is if your LNB drifts and say instead of 12000 for a frequency its at 11996, the Traxis wont lock unless its on 11996 (most other boxes would lock on it). When I helped someone aim their dish, the frequency they wanted was 12044 and it would lock at 12041 or 12040 and that was it
Ok, I'll need the old thread on this thing. It arrived a few days ago and just now getting around to opening it.
I can see I'll need a different programming cable. Female on one end then male on the other. Also, is there a possibility of converting my Coolsat 4000 list to the Traxis format? I may be out of luck on that one. I'll stick around today to see some input.
EDIT: Nevermind, read the old thread. I'm screwed on that. :mad:
DVB-S/S2 and ATSC Combo Cards
New RTN in Oklahoma Finally.
