Trouble getting OTA DTV stations in chicago | SatelliteGuys.US
Joz
I'm trying to determine the DTV station number for the local channels in chicago. I got most of them but I can't locate CBS-2 and WLS-7. Their supposed DTV channels are 3 and 52. I can't get either. Is this just due to location. I'm in Naperville I guess about 50 miles from downtown. I get the other stations with 7 bars signal strength.
Any help?
Looks like you are about 30 miles from the antenna farm, which is slightly north of east from you.
WBBM-DT is on channel 3 at 4.4KW.
WLS-DT is on channel 52 at 152KW.
Both seem to be slightly under powered comparing with other network DT channels.
What type of antenna are you using? Low VHF channels can be a problem.
You may need a mid-range UHF/VHF antenna with a preamp for solid reception.
Does anyone else in your area have a problem with OTA ch 3 and 52?
Not a lot of help, but some ideas.
Strict South Florida Homeowner's Association
OTA Antenna Issue??
