Unfortunately my first post on this board is about a issue I am having with my Cox cable HD service and hopefully someone can help me out. It is more an issue I believe with the way the condo was wired than with Cox cable. Here is a overview on how things are setup, sorry about the long nature of this post.
I am a renter and live in a nice condo in Phoenix, Arizona. However, who ever bought the condo either cut costs by having their cable daisy chained or that's how the builder decided to do it!
Currently in the condo there are 3 cable jacks, one is in the Master bedroom, another in bed 2, and finally one in the family room.
Cable feed comes in from the street to a Phone/Cable closet on the bottom floor which houses all the cable and phone for the building I am in, only community staff and cable/phone providers have access to this room.
From this closet/room, there is a cable feed running up to my condo unit directly to the Master bedroom outlet. After unscrewing the plate I noticed that this line coming from the downstairs utility room is being split using a standard non-amplified 5-1,000mhz 3.5 GHZ db splitter into the master bedroom plate and then running into bed 2.
From bed 2 it repeats itself, using the same splitter and then running it into the family room where it directly connects to the cable plate. In the end the family room is the last line of the daisy chain, you think they would have done it reversed!
The issues I am having is that the TV signal on my Samsung 56'' 1080p display in the family room looks bad during most HD programs. I am seeing a lot of digital noise, lots of image bleeding and simply not the picture quality I should be seeing.
I am using the standard Cox HD scientific Atlantis HD8240 box with a monster 800 series 1 meter cable running to the Samsung.
I know there is really no way of getting around the daisy chain setup the builder has done, and there is also no way of me doing a direct feed from the first spit that's located in the master bedroom and running that into the family room because I am on floor 2 of 3.
Is there a good way I can boost that signal into the family room from the incoming line in the master bedroom? Some kind of good amplifier anyone recommends? Or am I out of look with the way the condo was wired?
Thanks for the help on this issue everyone!
