TRX1520 Help | SatelliteGuys.US
TRX1520 Help
ga_relicman
3
I'm just now getting around to installing my TRX1520 receiver. It's been in my shop for at least a month. I don't have a owners manual. I'm having problems wiring it up. I get a error message saying no return pulse. The dish will move some when I hit either east or west, and that's when the error message comes up. Can anyone help me out here?
The Old Relicman
I'm not as good as I once was, but I'm as good once as I ever was!!
Make sure the smaller 2 wires are connected to the actuator return pulse and gnd (no 5v). If they are and you still see that error, you probably have either a bad wire or a bad reed sensor.
If you hooked up the Reed sensor to +5Volts, it's probably toast.
Upgrading to KU
not getting all tps on dvb.
