I have a DirecTV HR20 DVR which I am attempting to expand to 2 terrabytes capacity.
Here is what I have done so far...
I purchased a Western Digital AV-GP 2 terabyte hard drive. I opened up the DVR and replaced the internal 300GB drive with the new drive. I booted up the DVR and let the machine format the drive. According to another website, the machine would automatically format the drive and this is all that would be necessary. The start up sequence got to the point where it was "calibrating the satellite settings"? ....or something similar sounding. I do not remember the exact terminology.
I then called DirecTV's tech support and they refused to give me any support since supposedly I am not supposed to swap out the internal hard drive.
I then put back the original 300GB internal drive, booted up the machine and then connected the 2TB drive through the external SATA port on the DVR.
I let the machine run all night so that it had plenty of time to do whatever it need to do like formatting the new drive, if necessary.
This morning I checked to see if the machine had recognized the new drive by checking the on screen menu to see how much drive space was available. It said only 5% capacity is available. The DVR had not recognized the new drive since it would be showing much more available drive space.
This morning I called DirectTV again and asked them what I need to do to get the DVR to recognize the external hard drive. (I did not want to confuse the lady by saying the second "external" drive is actually inside the DVR). DirecTV told me that this DVR will only recognize two different 1 TB drives. They said it would only recognize the Western Digital WDG 1S10000 and the Seagate ST3000SCA 109RK.
On the internet, I saw this website...DVR Expander for DirecTV Is this my only option? I already spent $208 for the 2TB internal drive.
BTW, I was able to fit two hard drives in the HD20. I used a 4 pin Molex to drive power connector splitter-converter to power both drives. I also plugged the 2TB drive into the SATA port on the motherboard where the external SATA port was plugged in. It would be nice to be able to leave both drives inside the HR20 case rather than having an ugly external drive box sitting next to my DVR. The WD Green AV drive supposedly runs pretty cool. I can live with an external drive if that is my only choice or the best choice.
I have built a number of high end gaming computers. This is why I tried, but so far have not been successful, at upgrading my DVR's drive storage capacity. There seem to be a number of similarities between a satellite DVR and a computer. Its the differences that are killing me.
One more question. If I were to use Acronis to clone the internal drive, would the machines BIOS recognize the capacity of the 2TB drive? Would a cloned 2TB hard drive work? Would Acronis also transfer the same drive format? Is this a FAT32, NTFS or some other drive format?
Thanks for the help.
David M.
David M.
