Trying to figure out if I can see the birds... | SatelliteGuys.US
madpoet
Too Much Hi Def!
1,154
Vernon, CT
I'm in the process of trying to find a spot on my property where I can see the satellites for Dish. Does anyone have any good pointers for it? I have the azimuth and elevation program, and a good compass. How hard and fast is the rule on trees, etc;? Does it have to be an absolutely perfect nothing in the way view, or if there's a tree a hundred feet in the distance but in the path am I screwed?
And second, I have a 24" round dish that is left over from my Voom install. Can I use this in any way, or do I need to get a new dish? I want to pick up HD, my locals, etc;
Thanks,
MP
basically, you'll want to be as far away from the tree as it is tall. If you have a 40 foot tree, placing the dish a minimum 40 feet away from that tree will give it line of sight over the top of the tree.
Forget the 24" dish for DISH Network their dish is 20" and looks at 2 satellites. If you want to use two 24" dishes you can aim 1 at each DISH location. Seeing we don't have a location for you, you may need a 39" superdish for your locals. :(
Sorry, I'm in Manchester, CT :). Ah well, most of the deals come with a dish anyway. I'm still not sure about trees, need to get up on the roof and take a look I guess.
So, you're in the Hartford-New Haven DMA. All you need is a Dish500 for HD (except CBS-HD, NY which is on 61.5) and your locals. That 24" Voom dish could work for 61.5, it's already aimed there. You would have to get waivers for CBS though.
Not so fast there! The elevation angle for Manchester CT is 23 degrees for 119. The tangent for 23 degrees is about 0.425. That means that to clear a 40-foot obstruction, you'd need to be (40 / 0.425) 94 feet back!
Of course, that's 40 feet of difference. If you're 20 feet up on the roof, you'd only need to clear the top 20 feet of the obstruction.
BCS: carload is correct - what you said applies to where I live (elevation 43), and maybe where you live, but not everywhere. ;)
madpoet: The LOS must be 100% clear. Note that an installed dish APPEARS to be looking around 20 degrees lower than it really is. This is due to the offset mounting.
THe problem is that west for me goes uphill into woods! Saw a good idea on the faq thread for using a straw and a protractor. Might have to give that a try. In looking at the compass headings today though, I think I'm in trouble. I might have to consider paying a place for a site survey or something. THanks for the advice so far guys.
For sure, that would be a 45 degree elevation so that rule does not work up north. A better rule of thumb is twice the distance from the tree as its height for us.
My inclinometer does not have a closed look window, only a indented edge, so I just place a sticky address lable on that edge to make a look site for checing out stuff. Realy brings in the accuracy.
I must be very low tech then. I just usually eye it and say I can or can't. My record for just hooking a dish up and having a signal right away is 20 times in a row. It has to be fine tuned after that but still, I was a bit freaked out the first few times.
did I ever mentioned I barely passed geometry? I was more interested with the curves and angles of the girl sitting next to me.
Them damn girls next to me. Only for them I'd be runniing the hubble by now. With their damn feromones and hormones attracting me to them.
Here is one of my most favorite stories, hope you folks like it, you seem like you would.
If you ask a lot of people what the stupidest thing they ever did in their life was, most people are going to have to stop and think about it. Some people won't know.
For me, it's easy. As a matter of fact I could probably list one through ten without much thought. Let me tell about number one.
I live on a farm 20 minutes north of town. It was a weekday night in February 1998. It had begun to snow in that sad sickly way that starts with freezing rain. There were important things going on at the office the next day and more snow forecast, so I planned on driving my 1979 Chevy 4WD.
This truck is equipped with a plow.
The hydraulic lift on the plow has a leak.
Driving this truck in the best of conditions ain't exactly easy. It used to be an automatic, now it has a Ford 3 speed manual jury-rigged into it. The clutch mostly works, and it sways like a drunk over the slightest bump. With a plow on the front, it's as scary as hell. Not only does it catch all the wind, and push you around, but the leaky hydraulics mean that at any moment the plow could fall down and catch pavement at 60 mph. I call this effect "unintentional braking."
To avoid this, I decided to load the plow (all 300 pounds of it) into the back of the truck. No weird aerodynamics and the added weight would give me stability.
In the driveway I unhooked the plow, turned the truck around and backed it up for easy loading. I tilted the plow face down so the open end was on the ground and started to lift one side. In spite of the slippery conditions I got one end into the bed of the truck.
At this point in time I went around to the other side of the plow and performed the single stupidest act of my entire life.
Anybody who knows how to walk will understand that the only thing that kept the plow from sliding off the truck was the friction of it's edge against the blacktop. As soon as I lifted there was no more friction.
With almost casual disdain the plow slid off the truck, pushed me over backwards and pinned me against the driveway, covering my entire body neatly in the concave space between plow and blacktop. From tips of toes to shoulders I was pinned. Though unhurt I coldn't move.
I laid there face up to the freezing rain which produced a maddening itch on my nose. For 20 minutes or so I was able to reflect on my stupidity, and idly wonder if it was going to finally kill me. The pressure was such that I couldn't even wriggle. All I could do was murmmer "...help," while the dogs watched me disinterestedly.
Finally my wife came out to see what I was doing. After 3 years of trying we had just learned she was pregnant.
"Are you ok?" she asked.
"....help," I said.
"What are you doing?"
"....help,"
"Are you stuck?"
"How did you do that?"
"....help,"
"I can't move that. How'd you get under there?"
"Urrrgh,"
"I'll go see if Woody's home."
"...hurry,"
Walking carefully across the ice she goes up to the house and futzes around for a few minutes, before getting in her car to get the neighbor.
I stare at the rain.
Five mintues later she comes back.
"There's nobody home, but I called 911. Somebody's coming."
"...please,...help," It's hard to breathe now. My legs and arms have pins and needles in them, I feel sleepy.
"This is your own fault. How did you get under there?" She studies me for a moment, and for the first time looks concerned. "I'll be right back."
She goes into the garage and returns with a tow chain. She hooks one end to the plow hookup and the other to the truck hitch.
"I'm gonna pull it off you."
"...ok."
She gets in the truck, puts it in gear, and drags the plow ten feet down the driveway.
The problem is I'm still under it, just worse for wear for having been dragged 10 feet under a 300 pound plow.
"Are you okay?"
"...ow,"
"You're really stuck. I don't know what to do."
"...help."
At this point, and I swear this is true, my wife comes up with an idea.
"Your heads still sticking out. I could tie your head to a tree or something with a rope so you won't get dragged, and pull the plow off."
My teeth are tingling now, and the whole thing seems kind of silly. It's hard to breathe, and even the rain doesn't bother me.
A short time later, probably no more than a few minutes, suddenly I can breathe. Then there's pain as the full weight of the plow settles back on me. It wakes me up to full alertness. I realize that there's an excellent chance I'm about to die.
"I can't go any higher. It slides."
My wife has placed the truck jack by my shoulder and lifted the plow a few inches before it slid again.
"Don't do that." I say. "It hurts."
"Shut up."
She leaves, and comes right back. She starts with the jack again.
"don't..."
"Shut the f**k up!" she says. She never curses.
She jacks the plow up a little, and props scrap wood she got from the garage on the edges. She goes to the other end of the plow and jacks it up.
"Get out."
I try to wriggle and push but I can't get any purchase.
"Now!"
"I can't"
She comes over, sits behind me, puts her feet on the plow and grabs my head. She pulls, I wriggle, and little by little I come free. It took the Fire Department another 10 minutes to get there.
The number two most stupid thing I ever did was remarkably similar.
I bought a motorcycle.
It was a street bike, but I liked to ride it around the fields, without a helmet, ...real fast.
My wife said I would wreck and kill myself.
She was walking up from the fields while I was riding around, as I was passing her up the path (no more than 15 mph) the dog spooked in fornt of the motorcycle.
I swerved and gently laid the motorcycle on its side to avoid hitting our dog. When the footpeg touched the ground, the motorcycle flipped with me on it. It landed on to od me, still running.
"I told you you'd kill yourself riding that thing, don't expect me to feel sorry for you!"
"Arrrgh!" The motorcycle was still running, the chain cutting into my leg in a whimsical manner, the tailpipe trying to make a medium rare roast beef out of my thigh.
"Help, turn it off!"
"It's your own fault. Help yourself. I knew it would happen."
Finally I shut the motorcycle off. I start trying to push it off me, but only succeed in rocking. Each time I do, a rock digs into my back. My wife starts giggling.
"I promise I'm going to kill you."
She starts laughing.
"Please help me. I'm bleeding. I hurt my knee. The pipe is burning me. Please."
Now she really starts giggling.
"You're trying trick me. Yo said you'd kill me. If I get near you, you'll grab me."
"No I won't. I was just kidding when I said I'd kill you."
"You weren't kidding. You're gonna kill me."
"YES! IF YOU DON't &^^&ING HELP ME GET THIS GOD&*$#M &*$%ING THING OFF ME I'M GONNA RIP YOUR HEAD OFF!!"
She starts giggling uncontrollably.
"AAARRRRRRGGGGGH!!!" With a Herculean effort, I push the bike up enough to extricate myself.
My wife runs away laughing.
I limp up to the house grimly after her, like Jack Nicholson in _The Shining_
Back on tangent... ;) It looks possible if I pole mount the dish and secure it on the back of my deck. I'll need to read up on how to do that. I've got a gap in the trees that I think I can exploit, but it's going to have to be fairly precise :(. How much of a heading difference if there between the birds I need to hit? Not sure what channels are on which satellite.
Manchester CT, Zip 06040.
110 - Azimuth 243, elevation 29
119 - Azimuth 251, elevation 23
61.5 - Azimuth 177 (almost due south), elevation 40
You could get by with just the 110 channels, but why? :) Look for that 8-degree gap, or even two gaps 8 degrees apart. (Remember that each satellite is a single point, so if all parts of the dish can "see" each of those two points, you've got it all.)
I included the 61.5 in case you needed it for locals, HD, or Classic Arts Showcase. If you want that, you'll definitely need a second dish.
One more thing, I got those numbers from Dish's calculator, so those are the apparent azimuths. That is, you don't have to apply any magnetic correction factor; that's the direction according to your Manchester compass.
Is the 510 worth it?
Updated L2.81 Release Notes and future fix notes
