Trying to get local channels | SatelliteGuys.US
pstef
3
I have had DirecTV for several years. Within the past couple of weeks they shut off PBS. In order to get my local channels I was told that I had to purchase a newer dish (which arrived today). It has the triple feed, multi satellite LNB. Can I simply connect the cable to any of the four connectors and I'll be ready to go? What else do I need to do? My receiver is really old (one of the original RCAs). Do I need a new receiver as well?
You can use that old receiver, but it will NOT see anything that is on 110/119, so it will NOT get your local channels. Normally, D* also offers to upgrade any non-multisat receivers for free - maybe you should call back & ask them about this. (they normally tell you this at the time you order a triple dish)
You should have gotten a free upgrade from Directv including installation for your local channels. Directv will also upgrade your receiver free so you can receive the additional satellites.
Phase III transponder signal strength
DirectTV Puerto Rico
