Trying to get locals! Please help. | SatelliteGuys.US
ssayet
5
Arizona
I just moved into a high rise condo in Tempe Arizona. When the DISH techs came to install my system they could not get the western setup as my building was blocking all of the satalites. They did install a eastern Arc setup... The only problem is i do not get locals "Actual locals" or even east coast locals. I do have a address in New York as well and tried putting my Ny address on the account and no such luck... Any ideas. thank you in advanced.
Have you tried an antenna????
I assume since you are using easteren arc you have hd????
This may work well in Tempe as you are close to Phoenix.
This may mount well on a balcony
Walmart.com: Philips MANT940 Indoor/Outdoor HDTV Antenna: TVs
Walmart.com: RCA Suburban Mini Yagi Digital Outdoor Antenna with Mast: TVs
This may work well indoors near a window
Walmart.com: PHILIPS DELUXE FLAT AMPLIFIED ANTENNA: TVs
Good thing about wal mart is you can try something and if it does not work they will take it back.
61.5 Signal Lost?
Is C-SPAN 2 part the Welcome Pack?
