TS 360 with cable | SatelliteGuys.US
TS 360 with cable
mikeray
2
I just changed from Direct TV to cable. Is it possible to use the TS-360 with cable. When I try to boot it, it stops when it can't find the dish. Is there any work-around for this?
I have used the 360 here in Phoenix with Cox Cable. The 360 will only decode analog cable channels. If you want to view HD channels, you will need a QAM tuner. You can go into the dish setup and select "no dish." After you do that you can go in and scan for available cable channels.
Multi Switch to Diplexer for TiVo, help!
DirecTV and signal strength
