Tuner 2 Signal lower than Tuner1 Why? | SatelliteGuys.US
hoos51
167
I just did a signal check and Tuner 2 is lower on all satellites. Is there a reason for this? Thanks in advance.
HR21-100
Sometimes my OTA does that as well. It works itself out most of the time. A couple times I had to reboot to fix that problem.
I just rebooted and still lower. All channels are coming in fine , was just wondering if this is the beginning of an issue >
I just saw this under one of the releases as new and improved , maybe I didn't get the fix :)
  • 05 - Tuner 2 low signal level readings HR21-100 only
I need a channel 13
when all channels are HD
