turn on my 505 i get diagnostic screen | SatelliteGuys.US
pastafazoule
24
the last 2 days when i look at my 505 in the morning the clock is off so i have to reset by holding down the button,so when i do that i got this diagnostic screen that has like all these numbers on it and running time in the right hand corner,the first day i stop it and reset and it was normal,is this some update or something
update the second day i let it run thru and it finished what every it did and it went thru its reset and then i turned it on and it was working
thank you what kind of update was it,and again thanks
F0 fixes the striping issue, where a green/blue/brown band would appear on the right side of HD channels, as well as the jump to channel 200 fix where it would automatically go to 200 if you missed a number, eg 55 instead of 555.
