??Turner?? | SatelliteGuys.US
??Turner??
vvovv
57
The Sv 8K has a ATSC turner.
I was wondering is there a difference between a ATSC turner and a QAM tuner
If so what is the difference and is there a fta receiver with a QAM tuner
Thank you
Still a little confused.
QAM tuners can be likened to the cable equivalent of an ATSC tuner which is required to receive over-the-air (OTA) digital channels
So I can't plug a cable tv into a atsc turner and receive the HD channels.
Would be very cool if a fta receiver did have a qam/atsc turner
I need to upgrade my antenna since I have a cheap one that clips on my dish
and I loose signal sometimes which really makes me made.
If so what is the difference ...
For our immediate purposes, it might aid understanding to switch to compatible terms. As in, ATSC is a specification, and QAM is a modulation. ATSC uses a modulation referred to as 8VSB. So asking about the differences between 8VSB and QAM might be more appropriate. (Equally possible, instead of modulation, we could ask the more general question of differences between ATSC tuners and cable tuners - of which modulation would be a component).
I'll stick with modulation. They are both variants of the more familiar AM, but similarities end there. It might be sufficient to say that there are large differences in the nature of the carriers and filtering necessary to extract the data. This is enough to conclude that they are distinctly imcompatible.
The DVICO FUSION cards will receive both ATSC and QAM (64-256). I have the HDTV5 USB GOLD box and it receives both OTA HDTV and cable. (does not receive satellite) My cable channels have however all encrypted.
What is this dish that everybody sells here
Has PBS moved off of AMC3 or am I going crazy?
