TV Volume Regulator | SatelliteGuys.US
TV Volume Regulator
If your TV supports volume normalization, it should suppport it in all audio connections to the TV (mine does), but all manufacturers are not the same, so they may or may not bind the normalization to all audio inputs.
Plywodstatebum said:
Does anyone know if these things will work with D* HD system? I'm tired of the commercials blowing us out of the house. Do they change the 5-1 sound also?
I hear ya. ESPN is notorious for this...
This is what I'm talking about.
The TV Sound Regulator, can be yours for only $49.95 (plus *$7.95 S & H). As an added bonus, International Control Systems, LLC, will send multiple purchases of the TV Sound Regulator (a maximum of 5 units), to the same address, all for the one *$7.95 S & H charge (purchases must be shipped at one time). You won't find a better value anywhere!
Satisfaction Guaranteed!
60 Day money-back guarantee
Full one-year warranty
If you're not satisfied, we're not satisfied. Just call or email us.
http://www.tvsoundregulator.com/html/works.htm
Opps, stupid me, didn't know it was a seperate product. <g>
While there is no evidence of hd(or 5.1) support (or lack thereof) on their site, judging by the contents (nowhere is HD or 5.1 mentioned that I could find for instance), and the wording of stereo seperation, I got a feeling, if it supports the audio connection in use in your system it will do it's job, now as far as I can tell, the regulator is meant for stereo, so it may pass the 5.1 along, but probably won't normalize it (except maybe 2 channels), or it will drop the 5.1 completely and mash it into 2 channels, if it passes the 5.1 and only affects 2 of the 5 and normilzes the 2, youll have 2 of the 4 in 5.1 normalized, the rest not normalized, if that's the case, then you might be able to run a few of these in parallel, depending on your wiring to normalize all 5.1.
In short, it sounds like it won't matter if it's HD or not, but, it will matter how the audio is delivered to the regulator then to the audio system, and it may or may not pass 5.1, if it does it will only regulate 2 channels, or I could be way off, just giving my input. Probably would be best to ask the makers of the product.
I believe the TVSM device is analog audio only.
I use the similar Terk VR-1 and it works well. Check it out at Crutchfield and it's sold on eBay.
It will be nice when they built this into Dolby & DTS. (5.1), My mitsu TV does have this and it works great on cable, not at all on satellite. That is becuase my Yamaha is the center of the media system though.
Splitter from D* receiver
Acces to XM Website when D* launches their channels?
