I have tried everything it is in dual mode. Shared view disabled. Set to the correct channel. If I run RCA TV2 works fine. I have even run a coax straight from TV2 out to TV2 with the result. Box has been replaced. Any help would be useful
What channel do you have the TV2 set on? 60 for TV2 62 For TV1 both show the TV1 Icon
Power the TV off, then back on to confirm. Done
Also, what receiver model are we working with? Sorry 722k
Not sure I understand your questionDoes the rf output on the receiver match the tv?
Checked both for sure, Dish Tech support was stumped as well figured I'd reach out to the community on this. It seems the TV2 Coax output is stuck on TV1.Initial guess is either the cable is connected to a TV1 only output, or the TV2 is set to the wrong channel
Limited time offer
