TV2 issue | SatelliteGuys.US
TV2 issue
shodobe
606
4
NorCal
I use a 622 with another TV as the TV2. I know with the TV2 you don't get HD, but I want to be able to get my OTA locals on it. Is there a problem using an A/B switch to obtain this? Just run the antenna feed to one side and the sat signal to the other side. Switch back and forth when one signal is needed. Will there be any interference from one side or the other? Thanks
So a simple A/B switch would work? Two signals in, OTA and sat in, with a simple toggle switch. Back and forth as needed. Sure beats buying another reciever just for this.
Current Hopper and Joey Software Versions
Critical of the Hopper Rollout?
