TV2 on 622 picture degrated. Any tips on what to check? | SatelliteGuys.US
shortspark
330
88
texas
Last night I went to bedroom to watch tv (this is my TV2). I went to the grid and noticed it was fuzzy or I should say it had a lot of grain to it. I went to all the channels and found the same thing. This morning it was the same. My TV1 is where I hooked up my 622 to a projector via HDMI. TV2 is a Toshiba tube tv.
My projector picture is perfect. When I go to my other inputs on the Toshiba (DVD player, VCR and a Samsung set top box to receive HD via antenna), the picture is also perfect. It is only TV2 that is degraded and it only happened in the last day or two. I did the diagnostic testing and all is shown as okay.
Is there anything I can check or do to try to pinpoint the problem?
jiggle around the cable connector. its probabbly bad connector or might be bad cable. tv2 is analog signal so you will be snow or grain pic.
also take small piecer or coax and run it from tv2 output to that tv1.
Archos 705 w/plugin not working so well
Dish Customer Service Phone Nr Down?
