Has anyone tried attaching an antenna to the TV2 out to broadcast their signal through their home? How does the picture quality compare to using a wired connection?
I've been doing exactly that for years with both my 722 & 622. Works great. My antenna is amplified, maybe that's why. Just use a splitter in reverse. TV2 and antenna on "outputs" and existing coax to other TVs on "input".
Ed
So you're saying that the millions of wireless video transmitters already sold, are all illegal?The FCC prohibits retransmission.
Are you talking about a regular antenna amp? How much gain? Do you put the amp on the TV2 output, or the combiner (splitter in reverse) output? What kind of antenna do you attach? So you're saying that the millions of wireless video transmitters already sold, are all illegal?
Not if it is done OTA in a manner that could interfere with licensed broadcasts.retransmission is legal for own use?
Ed,I've been doing exactly that for years with both my 722 & 622. Works great. My antenna is amplified, maybe that's why. Just use a splitter in reverse. TV2 and antenna on "outputs" and existing coax to other TVs on "input".![]()
Of course they are still sold, although I don't see a single box like my Homer Technology HTM9000 still being built.do they still sell them?
be careful, we aren't talking about the transmitter/recevier pairs that operate at 2.4Mhz. We're talking about something that retransmites an actual NTSC TV signal.
It is/was my belief that re-transmission OTA was forbidden at any level. However, Dish has a drawing showing just that setup as a means to extend RF remote control signals. The OTA antenna at the remote location is the little stub antenna normally connected to the Remote Control connector on the back of the receiver....
I think you and harshness are mistaken. Sure, I can't turn on a high powered transmitter and interfere with a commercial TV station. But I believe low power transmitters are perfectly legal due to their short range and negligible threat to the megawatt broadcasters. If there is no threshhold below which NTSC broadcasting is legal, then we can guess why Homer Technology went out of business.
Years ago they sold devices that used either batteries or an adapter that accepted video and audio in on RCA connectors and transmitted on a UHF channel. I still have one that xmits on UHF Ch. 14. Mine never worked very well.
Not totally correct. Of course the antenna serves to receive the RF remote signal. However, it also sees the modulated receiver output of TV1 and indeed will transmit that signal OTA, albeit weakly. That modulated signal comes via the splitter to two outputs one outlet to TV2 and the other outlet to the stub antenna.the drawing showing the remote extender doesn't count because that is a receiver, not an transmitter. The remote is the transmitter.
I suppose getting the last word is important, but the drawing shows a splitter.not if you use a diplexer
Limited time offer
