Tv2 Pq | SatelliteGuys.US
Tv2 Pq
js6425
316
Milwaukee, WI
Ever since we changed our 625 to a 622 the pq has been horrible on the TV2 tv (really, really grainy). How can I fix this?
Do a auto channel scan on you're TV2 from the TV's menu.
Also, make sure the TV2 isn't running through a splitter used for youre previous cable tv. If it is disconnect it and barrel connect it together.
Also if it is going through a VCR, make sure it is on the right channel. If that doesnt work, unhook it from the VCR and hook it directly to the TV.
Hope one of those help you.
I'm assuming your TV 2 is the same for the 622 as it was for the 625? If so, you may want to try another modulated channel. For example, if it's currently on channel 73 (cable mode), try placing it on channel 21 (antenna mode). A difference in frequency settings can make a world of difference.
129, 61.5 or bigger dish ?
I want DishHD with several receivers
