Tweeking the BUD | SatelliteGuys.US
Tweeking the BUD
WyrTwister
769
Tweeking the BUD
For those of you that have both analog & DVB-S on the bud , I am finding the best wayt o tweek the dish is to first tweek on analog .
Then go to DVB-S and tweek some more , watching the signal level and quality on your PCI card software or on your Set Top Box .
I ma sure you vetrans already know this , but I am a C band newbie . :-)
Latter ,
Wyr
I dialed in the arc on my dish with a Pansat 3500s.
It was a matter of guess the position, blind scan, match the results with lyngsat, see what satellite I'm looking at ;). Fine tune from there.
It was nice to have the polar mount all dialed in when I hooked up the analog receiver and later the 4DTV.
That is pretty much how I did it on a PCI DVB-S card on Ku & with a motor . Had the signal meter by the computer . Move sat and watch for peaks .
But the card software does not have blind scan . Had to guess what sat the peak was & try scanning for channels . Time consumeing process . :-)
Fould have been easier with a STB & USALS .
Course , I always started out with the due south sat & worked my way east & west from that referance position .
Once I got the elevation under control , it was not that hard to hit due south sat on C band anaog .
Put a level on the horizontal part of the polar mount and used the accuator to move the dish untill I got it level . Then rotated east to west untill I hit the sat .
Then the same trial and error to find the rest of the sats .
Right now I have a very good picture on channels from AMC 3 to AMC 10 .
Latter,
Wyr
signal strength help
What happened to G9 (in the past)? Was it moved?
