Twinhan 1020 | SatelliteGuys.US
Twinhan 1020
MrMylesG
150
Perry Hall, MD
Hi Guys!!
I have a Twinhan 1020 DVB card that I purchased recently. Already I use my Coship to drive my 30" dish, but I want to be able to use the 1020 to steer the dish.
I would like to record some of the older movies on AMC4 to my hard drive. Then I can dump them to VCD or SVCD.
Anybody have any luck steering a dish with a Twinhan card? Thanks!
MrM
Your card should move an SG2100 with no problem, i'm using one with a Nexus, a 2x1 Diseqc and my signal meter works inline too.
Depending on what program you'll be using you'll need the right plugin. ProgDVB is probably the best overall program I've used.
Hope this helps.
