Right now, I have two STB's hooked up using loop out on 1 to feed the 2nd.
With the 1st in standby, the 2nd controls the dish just as if it was the only STB in the circuit. I never use them at the same time.
If I move the input from the 1st STB to the Twinhan and loop out to the 2nd and then the 3rd, can I still use my STB's as I do now?
I'm wanting to be able to have the Twinhan hooked up permanently, but, right now, loop out to my basement STB is the only way I can do it.
I still only want to use 1 device at a time. So, I guess what I am asking is will the Twinhan let the 2nd and 3rd STB's control the dish when no applications are running that have transponders tuned on the Twinhan?
I just want to know if anyone has experience with this before I start cutting cables and using connector ends. Thanks!
