Twinhan 102G and Microsoft Vista | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,713
29,486
Newington, CT
I just upgraded to Microsoft Vista on my main machine at home (Windows XP was acting funky and it needed to be formatted so I figured it would be a great time to try Vista) :D
Everything on the system is running on Vista except for the Twinhan 102G Card.
I look at the device manager and al appears ok there with no error.
Are there drivers or tips to get this running under Vista? :)
Thanks!
I think you are going to find several things that are broke between XP & Vista.
I'm assuming you are using one of the RC's, the last one I used, RC2 did not want to work with my Twinhan 1020a and the drivers installed ok, but, it would not work. Checked with MS and said the vendor would need to update drivers.
That said, once Vista comes out in January, it may have better drivers and more manufacturers will have upgraded their drivers for their hardware.
grusome
Feedhorns
Cativeworks 600s Premium Help
