Is it possible To have a pre amp mounted on the mast, fed by a power inserter and then add a UHF/VHF Cable signal amplifier inline towards the STB? Or will this fry something?
jim5506 - I'm really curious about that one! I'm assuming the diplexers are between the LNBs and the receiver or switch in which case they're already passing the power for the LNBs. So how can you also pass the power for the preamp that is likely different? The diplexers won't know the difference.Jim5506 said:Are you wishing to amplify OTA signal diplexed into a satellite cable run, or are you talking about amplifying the satellite signal itself?
For the former, if your diplexers pass the amplifier's voltage from the injector you can place an OTA pre-amp at the antenna and it will work...
That option (the preamp uses the same power as the LNBs) is still viable. I think that's the ONLY option in a diplexed system like I described - please correct me if I'm wrong...!Jim5506 said:...In fact there is a pre-amp that will use the voltage from the satellite receiver so you don't have to have a seperate injector...
i have the same radioshack preamp that was stated above. it is radioshck part number 15-2057Jim5506 said:The CM7777 (UHF/VHF) or the CM7775 (UHF only) are very good amplifiers with low noise figures (2.0dB on CM website).
Radio Shack amplifiers are not known for their low noise performance. They cost less and here you definitely DO get what you pay for.
The CM amps are 26dB on UHF. I would buy the CM amp myself if I needed one.
Limited time offer
