Is there anyway to get around the two wire inputs for a Directv dvr with dual tuner, I had a new house built and forgot to have two lines put in for the tuner. can i make one wire carry two signals or am i just SOL. Thanks for any inputs in advance.
does it have to be two separate from the block or can one line be split from the wall??
thanks for your help. its my own fault, I forgot the have the electrician install two wires at my tv stand
Revisiting this one. Has D* come up with a solution to the dual inputs thru one wire yet???
NP, I ordered one from Dave29 and it worked out great, very fast shipment and he also has splitters if you need them. If you haven't you might want to research exactly how the SWM8 works and with what receivers so you don't get any surprises.well it may be worth it, right now im paying for a dvr i cant use to full potential and would like to upgrade to HD dvr with VOD. THanks for the quick response.
Limited time offer
