Two receivers / one lnbf? | SatelliteGuys.US
Othea
176
Does anyone know if it's possible to hook up a second and third receiver to a single LNBF using a JVI 35-DTV34 multiswitch to split the R6 cable signal? An A/B switch isn't a practical option.
get a high frequency splitter (950-2200MHZ or above) and a DC block and hook both lines up
Unfortunatelly, one receiver (with the DC block on) will only be able to be on the same polarity as the other receiver.
I use to do this with G10..my Pansat controlled the polarity and the Viacast had to be on the same. Since most G10 stuff is Vertical, it was no biggie :)
Broke down and got a dual later
Looking for a better analog reciever / BUD positioner
I sold it
