This condition occurs when the transmitter fails a transmit pointing test. This indicates that the transmitter did not meet the minimum specifications required. This is likely due to an antenna installation problem. The antenna installer needs to fine-point the antenna. The transmitter will not transmit until the transmit pointing test passes.
Click here to re-run the transmit pointing test. Make sure that the weather is clear before running the test.
