When I first got SD everything was fine. Now I can't get the Eastern feeds of ABC, NBC, Fox and PBS. Only CBS. Anyway to get them back. Thanks.
Yes, I was getting both the eastern and western feeds. And all were in HD. Now only CBS east. I give the unplug thing a try.
Nope. Still nothing.
I can get 284. But it skips by 289 and 293.
OK I'll try it again. Also, the little light in corner stays green when get CBS but goes from red to green on channel I don't get. Could the dish be out of alignment?
CBS east in HD is on the F2 satellite on transponder 12 while the other east HD US networks are on transponder 15 on the same satellite. You might be just enough out of line to get tp 12 while not receiving tp 15. On tp 15, there is also CBC Regina in SD. Can you get that? If that cnannel is also not working, you need to fine tune your antenna.
thanks for all your help guys. I pushed the dish about an inch to the left and bingo all the channels came in loud and clear. Thanks for all of your help.
Limited time offer
