kingofku SatelliteGuys Pro Original poster Jan 29, 2007 191 1 Riverside County, California Sep 2, 2012 #1 SatelliteGuys Channel Master File Creator Doesn't seem to be working properly.
M Magic Static SatelliteGuys Master Lifetime Supporter Oct 12, 2010 7,498 4,853 Montana Sep 2, 2012 #2 Was not able to add a UDF file to the Sharing thread. I was able to SELECT, then UPLOAD, and then the only option was to CLEAR. ???
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,514 15,354 Mankato, MN Sep 2, 2012 #3 did it have a red ! after the file name....I just tried it and got that error I think Scott needs to turn up the max file size for that.....its at 2kb right now
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,818 29,806 Newington, CT Sep 2, 2012 #4 Give it a try now. I thought I set it up for 2MB and set it for 2KB.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,514 15,354 Mankato, MN Sep 2, 2012 #5 works now. Was able to at least attempt to upload a 1.56Gb file
M Magic Static SatelliteGuys Master Lifetime Supporter Oct 12, 2010 7,498 4,853 Montana Sep 3, 2012 #6 Yes it works now . File posted
