Ugh...my 722 is crashing | SatelliteGuys.US
vash1090
659
AZ
I've had my 722 two and a half years now, and it seems every 6 months or so it gets a new problem. Currently the EPG is incorrect, but it has been through: recording a show for 40 hours straight, recording for 0 min, not playing back, losing timers, involuntary restarts, disconnecting from connectivity, and forgetting an EHD is connected. I keep moving anything important to the EHD every month, but I just can't seem to get it to give me an actual fatal error so I can replace it.
New box time. Get timers written down or take pix of them off the screen it's time to get another 722.
Hi, I agree that your receiver needs to be replaced. I will be happy to assist you with getting your replacement set-up. Please PM me your account info, name and security code! Thanks!!
*IF* the 722 doesn't have the option to record the timers into the remote (722k does) ... and you need to get your timers listed.. you can try accessing your receiver through DishOnline.com .. and while its not as good as a detailed breakdown it at least gives you an all on one page list of all your current timers.
Then you could save a screen shot of it.
only problem with the "screen shot" ...I've 40+ timers.. :) pretty tall screen to capture all that.. though could probably also copy and paste the HTML into an HTML editor (email programs often handle html) too.. :) Its really a shame.. that the information it gets from our DVR's ... and displays ... but doesn't have a "save to file" doesn't have a "print" etc.. short sighted I'm sure..
New Dish Service Installed Today (211K)
